Hey Everyone,
I'm trying to convert my 1974 R to PCD 98 at the rear. It seems like most people just take a whole 126 rear assembly (brakes, hubs, axle shaft) and swap it onto their 500 swing arms, but 126 parts are nearly impossible to find in the States.
Does anyone have a good source for a rebuilt, 126 rear hub kit? I've been trying to piece the parts together individually, but I'm doing a terrible job, leading in lots of returned parts!
My current guess is that I need something like this:
- 126 Axle Shaft: https://mrfiat.com/fiat-126-p-rear-wheel-shaft.html
- 126 Rear drum: https://mrfiat.com/fiat-126-p-brake-drum.html
- Panda rear brakes: https://mrfiat.com/fiat-panda-uno-fiorino-seat-ibiza-rear-wheel-brake-assembly-set-185x30mm.html
- I also have these tripods: https://webshop.fiat500126.com/en/f...shaft/tripod-constant-velocity-joint-in-pairs
Does this look correct to anyone?
It seems like the axle shaft is for 26mm bearings, so I assume it will work in the stock 500 R hubs. It also looks like a fine tooth spline, I'm hoping it should work with my tripods. The Panda rear brakes should work with the drum, but does anyone know if the stock 500 R hubs will bolt up to them?
Any advice or recommendations would be greatly appreciated!
-Bobby
-Bobby
