Hello All
Hope you can help.
2011 Twin air and got a strange knocking recently. It sounds like a suspension issue so to start so took the car out and it is indeed knocking but sounds low down and does not seem to be speed related i.e frequency does not change with speed.
Jacked the car up and checked all the suspension components and wheel hubs - all tight and nothing loose. Whilst front was on stands I started the car and into first then second and there is a knocking. I then took the wheels off and ran the engine up again. The passenger side (short drive shaft) span freely whereas the drivers (long shaft ) did not all the time. When I held the passenger side break disk the knocking increased but again did not seem to be speed related.
Turned the car off and then when underneath and turned the shafts by hand and the drivers side did feel stiff.
Is this a drive shaft issue or gearbox/diff issue?
many thanks for any more diagnosis ideas before I start stripping.
Duncan
Hope you can help.
Duncan
