Technical  Help me identify the engine
Riba
Ennis
Last week I bought a 1995 Ducato campervan. Even though it says 2.5TDI on the sides, the installed engine definitely doesn't have turbo and runs like it doesn't. I suspect the engine has been replaced at some point in the past, but not being familiar with the Fiat diesel engines I am not sure what to look for. Can anyone identify the engine based on the photo? Another question is: for import purposes they will apparently look for the engine number. Supposedly it is stamped somewhere on the engine block. Anyone knows the exact spot?
Thanks a million!
Hi
The vehicle rating plate shows a 8140.47 engine which is a 2.5 Litre Turbo Diesel, so that tallies with the vehicle's badging.
The turbo is mounted quite low down at the back of the engine, so may not be immediately apparent. This is a non-crossflow design, so the alloy inlet manifold sits above the cast iron exhaust manifold. There should also be an intercooler with its large diameter air pipes. Low performance could be due to a lack of boost, e.g. because the wastegate or its control mechanism is seized.
If you are certain that it's a non-turbo, it's possible that it has been swapped for a 8140.67 engine, the non turbo variant. With 33% less torque performance is going to feel leisurely. See https://en.wikipedia.org/wiki/Sofim_8140_engine
Sorry, I don't know where the engine number is stamped
Thanks a million!
The VIN plate says 8140.47 which is an intercooled turbo diesel. Your picture of the engine depicts a similar if not identical engine.
To the RHS of the photo I can see the ribbed air filter inlet hose with a similar outlet hose at a lower level roughly at right angles and leading to the turbo behind the engine. There are two large smooth hoses across the front of the engine. The lower hose is the boost pressure hose from the turbo outlet to the intercooler inlet. The upper hose connects between the intercooler outlet and the inlet manifold, where the glow plug and solenoid valve for the flame starter can be seen.
This layout is similar to that on my 2006 2.8jtd, which is an 8140 series engine. Photo of turbo area attached.
I must question your assertion that the engine does not have a turbo. If it had been removed the exhaust and inlet systems would need the gaps filled.
More probably the turbo is not functioning correctly, perhaps with the waste gate lever arm broken.
Hi
Sorry @Anthony489 but in this rare instance, I have to disagree with you. All the pipework for an intercooled turbo diesel is there, and very similar to my 2.8jtd (8140.43s).
Thanks lads! The news about the lack of turbo has been passed by the mechanic who does servicing for a friend who collected the van in Germany. I didn't question it, but after your comments I will take a closer look tomorrow.
I would not recommend that mechanic.
Need to apologize for wasting everyone's time and not doing my homework before posting. Turns out the person who claimed there is no turbo was the guy doing the bodywork. He did a great job on the chassis though.
The turbo is there, just not alive and well. I will search the forum to educate myself of the common failures and start from there.
No worries, let's hope you get it sorted.
The pneumatic canister thing with the rod controls the wastegate, which in turn opens as required to limit the boost pressure to typically 12 PSI (I don't have the exact figure). One reason for low boost (= low performance) is if the wastegate is not fully closing. This can happen if the wastegate flap is stuck or if there is a problem with the control canister or linkage. None of these parts is outrageously expensive, but due to their position they are a faff to get to. Another reason for low boost is an air leak somewhere between the turbo output and the inlet manifold, i.e. in the pressurised air trunking and/or the intercooler. If the air leaks out you won't get full boost.
Before I start taking things apart, I need to verify that I have realistic expectations from the engine. Is there a simple way to verify the turbo operation? Getting over 129 km/h is a struggle - not really a complaint as I'm not in a hurry, and even a sligtest incline requires me to downshift to 4th gear. Maybe that is how it should be.
!29kph equates to 80mph. I have never driven my 2.8jtd at over 70mph. Yes, I think perhaps you are expecting too much. Maximum torque on the 8140.47 engine is at 2000rpm. The fifth gear in 5 speed boxes is a large step up from fourth, and I would expect to change down below 50mph.
The wastegate linkage in your photo does not appear to be broken. (There have been some reports of the pin or lever breaking free from the wastgate, allowing it to move without control.)
I cannot think of a simple way to confirm turbo operation, other than by fitting a boost pressure gauge. As the wastegate on your engine is controlled by the boost pressure, a gauge could be tapped into the small pressure hose that connects to the control capsule/cylinder. You ma not consider that to be simple.
Hello did you ever manage to sort out your Turbo issues Riba?
I am interested in the topic since I recently as well bought a Camping Car (Aryal 1A) 1997with a Fiat Ducato 230 CEMBC and the engine plaque quotes 8140.47 (which should be the tdi) but I as well think there is in fact a 2,5D (62kw) no turbo inside which corresponds with the papers .... .
Hope to learn from your experience
The Sofim 8140.67 was a normally aspirated 2.5 litre diesel. On the 8140 series engines the turbo is located on the rear face of the engine, when the engine is mounted transversely.
i have a 8140.47R motor. I studied today what that means and i studied the differences between 8140.47 and 8140.47R.
it seems nearly the same motor, the 47R has an electronic fuel injection pump. the 47 has a mechanical fuel injection pump.
My 47 R is 80 kWatt, 109 HP. i see in a list a 47 motor 85 kWatt, 115 HP.
Both are 2.5 Litres TDi, turbo diesel - direct injection - i means: with intercooler.
It are Iveco Sofim motors, SOHC, 8 valve, 2499 cc.
I am sorry @Algkungen but my understanding is that electronic fuel injection, common rail engines were first introduced to the Ducato model in 2000 with the Sofim 8140.43s (2.8jtd) being the development of the 8140 series.
The "R" suffix on your engine indicates that it has a catalytic converter fitted. The following information is an extract from this website.
8140.47​
The 8140.47 is identical to the 8140.27, has direct injection and a charge air cooler and provides 85 kW (116 hp) at 3800 min -1 ; Torque 245 Nm at 2000 min -1 . He was employed in:
  • Fiat Ducato II 2.5 TDI (1994-2002)
  • Iveco Turbo Daily 2.5 TDI (1992-2000)
  • Peugeot Boxer I 2.5 TDI (1994-2002)
  • Citroën Jumper I 2.5 TDI (1994-2002)
  • Renault Master I 2.5 TDI (1994-1997)
  • Opel Movano I 2.5 TDI (1999-2001)
  • Nissan Interstar 2.5 TDI (1999-2001)
8140.47R​
The 8140.47R is identical to the 8140.47, but equipped with an oxidation catalyst . He has 80 kW (109 hp) at 3800 min -1 / 256 nm at 2000 min -1 . The engine was installed from 1994 to 2002 in the Fiat Ducato II 2.5 TDI.
