Re: re
IF the car has ABS fitted the light must work or MOT failure.
IF NOT then its not part of the test.
Simple really.
Just because MOT technicians choose to ignore it doesn't mean its not part of the test.
Your Saab may not have a light so they are unable to test this section, the lighting sequence will not exist so your car will pass as long as the braking system is ok.
Your other car doesn't have ABS therefore it won't be part of the test, they will ignore any lights saying abs on the dash as they are irrelevant.
Taken from mottester.co.uk
I bought a car with the extra option of ABS.
The ABS has failed as shown by the ABS warning light.
The basic function of the brakes is unimpaired.
Would the car fail its MOT just because the ABS is non functional ?
Thank you. Stan
I am sorry to say that the regulations here are very clear. If there is a problem signalled by the ABS light, then that is an MOT failure. The Testing station would have no discretion at all.
The ABS system will have a special sequence of warning lights when the ignition is switched on to indicate that the system is functioning correctly. That is tested for the MOT. The ABS as such is not tested. So if, as a result of your ABS failure the warning lights show an incorrect indication, then that will result in an MOT failure. - MOTT
Its true that MOT testers may not have each individual sequence which is probably why they ignore it. Maybe its a universal system, I don't know but IT IS part of the test.
You may be able to take the bulb out out get it too pass but this is no different to sticking reflectors on or putting the cat back on.
Gaz
