OceanWanderer
Hi All
With my latest Panda misadventure meaning the removal of the gearbox, I have got to a point where I am well and truly stuck and hope someone can assist! For those who missed my last thread the gearbox literally went bang and locked up with oil leaking profusely from the mating surface between bell housing and engine. Further investigation showed that the gearbox oil is clean (no metal particles), the drive shafts are not broken or damaged - so I am leaning towards either the "big" diff bearings or possibly a broken diff... either way until I get the box out I wont know.
So far I have been able to do the following:
1.Remove the air box
2.Remove the battery and tray
3.Remove the clutch slave cylinder from the top of the gearbox
4.Remove the rear gearbox to chassis arm strut
5.Remove drive shafts (sadly the cups remained in the gearbox)
6.Remove the gearbox side top mount (2 x nuts & 1 x extremely tight bolt)
7.Remove the 4 x 19mm bolts around the top of the gearbox
8.Removed all bolts on the lower side of the gearbox 15/17mm
As far as I can tell there are no bolts at the back of the gearbox - is this correct?
The ePER CD says to remove the starter, for the life of me I cannot find it, roughly where is it and does it need to be removed?
I noticed in a diagram that there are locating dowels that hold the gearbox, how tightly do these dowels hold the gearbox in place?
I have been watching a couple of general FWD gearbox removal video on YouTube and once unbolted the gearbox seems relatively easy to remove - is this the case?
I have stopped for tonight as I got to the point where I was thinking tapping it with a 4lb hammer was a good idea!
Thanks in advance for any tips and tricks!
David
David
