Hey guys,
A friend's Punto was taken to a local garage because it was originally misfiring on two cylinders and then wouldn't start/run at all. We wanted it taken to a specialist (Sheldt & Pettet) but the idiot tow truck driver would only take it somewhere local. Anyway, these yeehaws reckoned the timing belt skipped and it had bent valves. When i got the car it had all the parts with it, but no valves. (Also no signs of valve collision on the pistons.)
This is how it was towed from their shop to me:
I have since rebuilt the cylinder head (16 new valves, new headgasket set, new timing belt and tensioner, etc.)
The old plugs didn't look great, so i put in a new set of plugs (And oil + filter) the car also has a new ECU and a new coil pack. I have double- and triple-checked the timing, which is correct. It seems to be getting fuel (There is fuel to the rail, the fuel pump runs.) but no spark. All i can think of is that the crankshaft position sensor is faulty. There is no camshaft position sensor on this engine. I have checked that the pulley is installed correctly, which it is.
I made a video of it turning over:
[ame="http://s7.photobucket.com/albums/y290/chrismca/?action=view¤t=MOV00979.flv"]
[/ame]
It doesn't always backfire like that, only has done once or twice.
I hooked my multimeter up to the crankshaft position sensor, when the engine is stationary i get this reading:
When turning over, i get these readings:
The range in resistance also leads me to believe that it is the sensor that's at fault. It is also the only sensor that tells the ECU when to fire the injectors and spark plugs. However, with no cam position sensor, i don't know how it knows the position of the cams though?
Is there something i've missed?
Any help would be greatly appreciated, i'm out of ideas here. Usually all i work on is VWs and Audis, i don't have compatible diagnostics for this car.
Thanks in advance,
-Moosey.
Thanks in advance,
-Moosey.
