General Heater removal?
MadMackem
Hi guys,
I'm new to the site, can anyone direct me to Heater removal thread or link pls. Seems to be a common fault by the looks of things, as I've changed the resister and checked fuses.
Cheers.
The fan is a piece of cake to remove.
Remove the glove box.
Underneath the glove box is a piece of plastic heater tubing, held in with one screw, near the centre, below the radio.
Once this plastic tubing is removed, you'll see the fan motor, which is held in with 3 screws.
It's a little tricky as there's little room to move around and you're working upside down, however, it's do-able and only takes 10 minutes.... tops.
