Technical Heater fan fuse
Toffbiker
Drejø, Denmark
Hello Qubo specialists :)
On my Qubo Multijet 2012 the fan for the heater has stopped working, in the diagram I can't see which fuse belongs to the fan? Does anyone know what fuse it is?
Thanks in advance
Lars
Hi :)
More likely to be a bad connection..
Is this Climate
. Or the twisty knobs heater?
I would remove the fan..
Check what voltage is gets..
And clear out Debris ;-)
You can connect fan up to battery voltage to check it spins ok ;)
Wiring around Resistor pack can get VERY hot.. melted parts are not unusual :(
it must be "the twisty knobs heater" i'm not sure mine has got climate, but is there not a fuse for it? It is not described in the manual?
