Technical  headlight relay ?
Just had a look again and pulling relay '5' makes absolutely bod all difference to the main/dipped/sidelights. In fact I couldn't tell what it was doing - everything was still working :confused:
I pulled all of the relays this time from everywhere all at once and the headlights still work............
I will carry on looking, I'm still trying to fix my fog/driving lights and I'm delving into the same area I suppose!
Lee
just been out and pulled EVERY relay in the fusebox, glovebox, and engine bay. headlights stayed on. there is also no relay click when you turn them on. so its not inside the car or audible in the bay.
id say stalks :-( were they new?
stalks are common faults on a bravo/a and its usually the lights that go.
what happene when they were last used?
does flash work/high beam?
sidelights?
front fogs? if front fogs work for NOW wire them up to the headlight plugs. so the headlights come on on the fog button. that way you can drive at night till you work it all out!.
if you take the bulbs out the fogs so their still only powering two bulbs they will be a-ok. no worries at all. you will need to do some custom wiring though.
tbh i dont know whats up. id still say stalks... kee on fiat boo has a few sets for a good price. you cuold always try another another set :p
just run the power to the power on the headlights. leave the headlight earth a is should work. just unplug the fogs instead of removing the bulb if you cant get in. make sure you water tight it though
no mate. but i pulled both of them aswell as the two small black ones (one on back one on front) none of them killed the headlights. although one i tihnk did stop the high beam working.
