Technical  headlight relay ?
well tried to put high beam spades on dipped beam but wire not long enough so ran a wire along but didnt work and blew fuse i changed fuse but now drivers side high beam not working as well as dipped beam so in a worse position than before fuse ok and bulb but not working domt know what to do now
there are seperate fuses for each side. are you sure there both ok?
it definatly should work. there the same bulbs, same resistance everything is the same, only way it can blow is if it crossed somewhere or it wasnt correctly insulated.
dont know what more to say other than stalks now... it definatly should not have blown it.
