Hi all,
Update on this issue. My issue is that the fuel pump wont run. I checked and swapped the relay and it doesnt seem to be related to that. Neither the inertia switch. I get 12v to the fuel pump connector when its unplugged, but as soon as I plug it in I get 0v near the fuel pump end. Pump runs when I connect a 12v drill battery into it, so its not a broken pump.
Next Im thinking about hunting the spot where I lose the volts between fuel pump fuse, relay, and fuel pump. If this is not the issue I have no clue and will probably give up on the car as I have no place to do any proper repairs or diagnostics.
