Technical Headlight error
Alessio98
Romania
Hi guys. I just switched my headlighs after a small incident. After changing I have a problem with headlight switch. If I switch it on 0 headlights are on, if I switch it on they stay off, if I switch it on position lights they work. Anyone knows how to solve this problem? Thanks in advance
Model
Grande Punto
2013
Is this the 3 position switch?
The wiring within the steering whrel are can be weak.. 😔
Plenty of people have had problem with Grande and EVO,
I suspect 2012+ is no different
Yes it’s the 3 position switch. Everything worked well until changing headlamps, I don’t think it’s the switch itself
I’ve had this type of headlight before and I switched to this
I’d suggest that the wiring between the two headlamps differs and your option is to either fit the headlight with the right wiring or reconfigure the wiring plug in the new headlight.
