Hard to get into and out of 4th
Dan
Driving along and it has just become slightly stiffer going into and out of 4th. It still goes in and out, but just stiffer. Its a Bravo 1.8 HLX. Any ideas? Please help as i have a 300 mile drive to do on thurs. :s
Any help appreciated. Dan
Any other simptoms ?
All other gears are fine ?
Members Site - - - - - - - My Site
No other symptoms at all. Can go from 3rd to 5th fine as well, just not into or out of 4th smoothly. Literally only started doing it this afternoon. Dan
I have no idea at all as ive only had the car a couple of months. Is it a do it yourself job for an ameteur? Dan
Bit lazy as i have a haynes lying around somewhere but what is an ok oil to use. Really aprreciate your quick replies. Dan
Thanks alot. Will give it a go and see what happens. Might owe you a drink. Dan
Hi dan, EXACTLY the same thing happened on my JTD. The mechanic thought it was something to do with one of the little selector ball bearings in the gearbox. Anyway, i seemed to notice it more when the car was on long journeys!
Anyway i bought some STP gearbox additive and some Gearobox oil (the best type, think it was castrol - halfrauds recommended it) and changed the oil. Really easy job to change the oil but you may need the big allen keys to do it (sorry dont kow the size of them! someone on here will tho)
When i changed the oil there was some metal shavings on the drain plug which i cleaned of beofre i replaced it. Since changing the oil, 4th gear still feels a little stiffer than the others to go into but it is far better than it was and im hoping it will just ease up the more i use it. My mechanic says that gearboxes are the sort of thing you just hae to run into the ground before replacing them!
PS maybe try adding to lots of the gearbox additive?
Hope this helps!
Stu
(currently in argentina!)
3
1K
Tommy K
T
3
7K
Steve
S
1
7K
Dark Lurker
C
3
796
Tommy K
T
