Have done most of the replacement however, i seem to have lost the "bolts" that connect the cable to the lever on the brake drums... can i just use a normal bolt and nut?
Thems not bolts, thems clevis pins. If you have lost them make sure you use a nyloc nut and don't tighten fully. They need to swivel. I'd also put washers on, and a dod of grease.
