I'd be looking carefully at the N/S one too just to check it's ok
Hope the drums come off without issue, they can be a complete nightmare
Thanks jrk, as always from you some good and very relevant advice. Can I just add that if someone is having trouble getting the drum off to not only make sure the hand brake is off - lever on the floor - but also that the screw adjuster is fully backed off so there is slack in the cables. If someone has over adjusted (over tightened) the cables in the past it may be that simply releasing the handbrake lever will not fully return the shoes inside the drums.Indeed they can. I remember one where the lining had detached and locked the wheel solid; unbelievably, the owner drove it home from the supermarket like this, and claimed not to have noticed until they came out next morning and saw that the tyre had deflated. The tyre was completely shredded, and the rim wasn't much better. I somehow managed to get the drum off without further damage, but the shoes, drums, tyre and wheel were all scrap.
Fortunately in this case the OP said they'd already had the drums off to check everything was OK.
For anyone who may be struggling, note that the holes in the drums for the locating pins are threaded (at least on OE parts); you can insert suitable bolts to extract a stubborn drum. Before you do, make sure the handbrake is off! Even yours truly managed to overlook this - once.
If replacing the shoes and the wheel cylinders are sound, note that the pistons have a tendency to drop out of the cylinders once the shoes are removed; if you're leaving it with the shoes out for any length of time, consider clamping them.
Thanks John I just got myself all confused today! I’m going to strip the rear brakes down tomorrow.. then I’ll follow your instructionsThe cables new won't have stretched, you are correct one is longer than the other.
It's correctly seated at each end? New starlock washers at drum end?
After fitting you set the auto adjusters(by racking round with a screwdriver) and centralised the shoes by pressing the brake pedal, then checked the drag on the drum, adjusting as required until just catching? You then applied the hand brake 1 click and checked, it should just start to drag fully on at 5 clicks?
I suspect the shoes-adjustment not the cables
Yeah your not kidding it can be tedious! But I’d rather be safe than sorry!!!If they are genuine ones probably equal, yours isn't that far off ive seen far worse.
You need to adjust the shoes by adjusting the auto adjusters first, press the brake pedal(hub on) rack round the auto adjusters spin the hub, press the brake pedal(hub on), remove drum and repeat as many times as it takes on each side, now adjust the handbrake tension fully off until you can just feel drag on the hub, then try 1 click drag should be evident now both sides, certainly at 2 clicks 5 clicks fully on.
Press the brake pedal release the hand brake and check drag on hub should be almost free(very slight drag is ok), road test a few miles feel hub?
It does take "Some time/adjusting" when you've had everything off and or replaced the cables, not hard just time consuming but always check the drag on any axle when doing brakes on completion it can look right but be bar tight our Mazda rear calipers are fickle in regard to tightening the bolts unequal equals smoking brakes
All done & dusted and working correctly thanks for the tips JohnThe cables new won't have stretched, you are correct one is longer than the other.
Drum brakes used to scare me not anymore I stripped em down again and double checked everything
Where do I get those star lock washers from? They don’t look like the usual flat type?
