Technical  Handbrake adjustment
Hi Can anyone please tell me the best way to adjust the handbrake on my daughters GP. I have replaced shoes and drums. Do the self adjusters actually self adjust?
Thanks in advance
They actually work ! But initially You'd have to bring them close to the drum: there is one position of the drum where you can access the adjustment teethed wheel through one of the rim hole (not very easy tho).
What I do is grinding-off the lip that's created by drum's wearing so insertion and removal can be easily done. Loose the adjuster at handbrake lever and tighten the self adjusters so you can just slip the drums back in place. Final adjustment is done @ the handbrake lever. As the shoes wear, the adjuster will compensate click by click …
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
