Hi guys, I have a problem with the handbrake,
Ive noticed the O/S doesn’t lock, I took the handbrake cover off because I thought it might be a snapped cable, but it’s not a snapped cable but this, the O/S cable is longer than the N/S,
I jacked the car up and I slightly put some tension on the cable and I noticed the O/S wheel did lock, so the cable seems fine it just seems slack, this brings me to the next picture, the left cable is the O/S wheel, there looks like there is some sort of threaded screw, would I be correct in saying if I unwind this threaded screw will it put tension on the cable? Because on the N/S cable I can’t see any threads?
My other concern is, as you can see the cables are different lengths, would all this be caused by worn brake shoes? Or just the handbrake not being set up properly from previous owner?
