- Joined
- Apr 6, 2012
- Messages
- 5,066
- Points
- 1,163
A few developments. The nights are drawing in so I have taken the pillar mounted boost gauge off and consigned it to the eBay skip.
http://www.ebay.co.uk/itm/262610610391?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
The blue illumination is brighter than the dash and made going round right hand bends in the dark ridiculous. Also pillar mounted pods are a bit 1998 and not really in my taste. :silly:
The Alfa wheels the car came with were sold on eBay to someone from Uruguay even though they were listed as "Collection Only" and I clicked no international bidders.
Gave the chap 48 hours to get in contact before canceling the order and relisting.
Some new arrivals.
The V-band on the flange is roughly 1mm wider than the rings...
...so I was going to have to either grind the flange ring or weld around the ring lip and grind it flat to make it fit.
From the back of the turbo flange face to the alternator heat pipe is 9.5 cm. From the V-band flange face to the end of the ring piece is also 9.5 cm. So as predicted by members of the GT owners club it will not fit without either relocating or removing the exhaust from the alternator and wrapping the down pipe to dissipate the heat away from it. The funnel section of the V-band flange is 4 cm from the face so I could use it with a ninety degree bend that's less than 5 cm from end to bend.
This won't give me the flexibility of a V-band set up but it will be a damn sight better than the down pipe that's on there at the moment. That's so crap I'm not even sure I should use it as a template.
Some new arrivals.
