Hi all,
Intro:
Brief introduction as I am completely new to this site. Been reading loads of posts on here and seen other people get some really expert advice and I've even used the sites tutorials to perform basic tasks on my girlfriends car that I would not have been able to do other wise! The punto is my girlfriends car and I'm desperate to get it sorted for her as I'm starting to feel really terrible for her!
I personally do not know much about cars but I have learnt alot from this forum so I feel that I know a little bit about this particular topic.
Problem:
Grande punto 1.2 petrol is cutting out when coming to a stop at junctions but also when parking and reversing. In my opinion also the car may seem slightly low on power if going up hill? This may not be the case though as I drive a bigger engine turbo diesel and it might just be that I'm not used to it although my girlfriend has said the same thing about pulling off on hills etc and lack of power on hills.
Things I've tried:
The problem pretty much arose maybe a week after I had changed the breather hoses on the punto after there was a smell of fuel entering the cabin. Both original houses had huge tears in and so both were replaced by myself using a tutorial found on here (thanks!) After a week the car went pretty much into a limp mode and was struggling to get over 40mph! And was also cutting out and struggling to start. Garage said it was the crankshaft sensor... replaced that and basically fixed the majority of the problem. Now what we are left with is a *slight* lack of power and also the same cutting out problem (usually after about 5-10seconds) when coming to a halt (both feet on clutch and brake) then when re firing the engine it usually needs abit of gas on the throttle to start otherwise it will just keep whirring and attempting to start without actually firing up. (From cold however usually works fine first time?)
We took it back to the garage they changed the spark plugs which I think was a guess by them but fair enough... seemed to improve a little bit but problems are still here. There are no error codes according to the garage but he took it out for a spin and agreed that it wasnt right as he experienced the same problems and has made a judgement that it could be the coolant sensor.
Additional info:
When I changed the breather hoses the smaller diameter tube seemed ever so slightly a smaller diameter than the one I had changed however I think this may have been that the original one with time has just become looser around the connector and so looked slightly wider.
I have also read about a throttle relearn. Maybe I should have performed this after installing the new hoses as surely the engine wouldnt have been used to a different ratio of fuel to air? (Maybe a load of rubbish but just a thought).
Thanks and apologies for a huge post I just think the more info for you guys the better picture you will have.
Intro:
Problem:
Things I've tried:
Additional info:
