im Axle Specialists
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Valve clearance check and adjustment [1,4 8V]<!-- google_ad_section_end -->
How to check and adjust the valve clearances, DIY.
Published by GrandePunto PL
03-08-2018
Difficulty Level: 3
User Rated:Unrated
Smile Valve adjustment job.
DIY valve clearance adjustment job is not that hard (just tricky). Try it!
0. Disconnect the battery (after job is done, you will have to set date and time, that's it). Then remove air filter box (as a whole or check air filter too - six, 7 mm hex screws). There are two, 10 mm hex bolts holding it. Mind the rubber hoses (two: big and small one), disconnect them. Then remove coil-pack module (three, 10 mm bolts), undo all connectors.
1. Undo all connectors on the engine computer and camshaft cover (earth point, brackets, etc.), or whatever you call it, "ECU". Then remove it. You don't have to, but if it's dirty, remove it for cleaning.
2. Next, remove ECU mount/bracket. Three bolts and one nut, all 10 mm hex. There is one weird connector, to unplug it, move grey plastic thing to the side (sideways).
3. Unbolt and move the cambelt top cover. Three 10 mm hexes. Mind the cable inside.
4. Remove the camshaft position sensor (not necessary, you can pop the cover with sensor installed). Visual check it (mind the o-ring, it may stay inside cover).
5. Same story with VVT actuator, electromagnet, whatever. Worth checking. If camshaft cover is dirty, you should clean it (then of course, all sensors, etc., must be taken out).
6. If you plan to replace cover gasket, it is advisable to mark and measure roughly, cover position on the engine head. If old gasket is still in one piece and it's still flexible, you don't have to change it (will not leak, don't worry).
Special service tool ("bracket", "jig", "fixture" or whatever you call it) is (may be) helpful only if you want to fit new gasket (you must "crush" it somewhat, force it into place). Worst case scenario is, that it can affect, disturb the camshaft position sensor readings. That's all. The "danger" here is mostly theoretical. Don't panic. But "just in case" measure, mark somehow cover position. Bolts are 8 mm hex (installation torque is about 8 Nm, some sources list 6-10 Nm range).
7. That's a classic design flaw (young inexperienced "wanna-be" designers, new generation). They should stay with good old design (all older models had camshaft cover removable, non interfering with ignition system parts - like mechanical distributor in oldest FIATs, or coils bracket in other). Now, "touchy" electronic sensor is installed...on "floating" cover. All depends on how new rubber will deform during cover installation = that's retarded.
8. Parts like this (covers) "like" to "seize". You will not be able to just move it by hand. It's so "stuck" like glued. You must "pop" it with some small pry-bar, screwdriver. Watch out, do not damage sealing surfaces (both sides: cover and on the engine head).
9. My cover popped out without gasket in it (gasket was "glued" to the engine head). That's a good thing, it will help align the cover, so there is no need for "special snowflake" jig/fixture. If you can, try to do that intentionally, pop the cover gently and try to keep gasket on the engine head side. One disadvantage is, you can rip the seal (small round seal, it is attached to the gasket). But that's not a big deal, they can be separated like this and installed again. If you are replacing gasket, make sure you ordered, bought, complete set (cover gasket + those small seals, technically not an "o" rings, cross-section is not round).
10. Engine head with camshaft exposed. Nothing special (yawn), has almost the same look for last 30 years or so (if you know the older models), it's so called "FIRE" family.
11. Valves layout. If you are not sure, just look at the manifolds (intake and exhaust). Easy.
12. During procedure we will turn the engine in the normal, working direction (clockwise), do it with 15 mm socket attached to crankshaft wheel central bolt.
13. Finally. Clearance checking is easy. Set lobe upright and use feeler-gauges. If it drags you are spot on. Good to have 0,01 mm increment step ones (0,05 mm step is little to "coarse", but good enough). Intake clearance ("gap") should be 0,30 mm, and exhaust bigger (obviously, it heats more), 0,40 mm.
14. Removing shims for the first time is "difficult" and tricky. There are supposedly "special" tools for that, but there's no need for such toys. Just use some big screwdriver and push it between camshaft (lobe "up") and shim. Trick is, to find suitable tool to hold (block, retain) "bucket tappet". For example modified screwdriver, it must fit tight under the camshaft (between camshaft and tappet outer edge, but be careful, don't crack/chip it). Then you can gently remove the shim (there are two notches, slots where you can place some mini screwdriver, scribe, whatever, "pointy" object), it's "sucked" into tapped (oil is holding it).
Use clean tools, and you will not scratch anything (don't worry, shaft lobes and shims are hardened well). Not good to use magnets, in theory it can magnetise parts (shims, tappets) and they will collect metallic dirt and/or make abnormal moves during engine work (or opposite - not make moves like rotation, valves + tappets + shims should spin to wear evenly).
Four (indicated in red colour) shims may be even more tricky to swap, because they're partially "hidden" under camshaft bearings. Just be careful (place your home-brew tappet "retainer/block" tool, move shim little bit, and try to push tappet from the top, vertically instead of horizontally like on the picture below).
15. Shim extracted (don't turn the engine while there is no shim in the tappet). Shims are 31,00 mm diameter. Thickness, "it depends". In general it should be something around 2,5 mm. As valves are wearing out, you will need smaller and smaller shims, especially on exhaust. Of course, you remove shims (one at the time), that will be replaced (if clearance is OK, leave it alone). But, sometimes there is possibility, to swap existing shims, so it's good to know all sizes (so I've removed all, one by one).
16. Random check, thickness spot-on (value as engraved on the shim). Notice, those shims are 3 decimal places (micro-meter). In the market most shims are 2 places, that's not a "problem" at all. And typical "step" will be probably 0,05 mm.
17. Write all clearances, make a chart like below. In this example all intake valves were good (no adjustment required), BUT exhaust ones are terrible (especially cylinder 1). May be trashed (burnt valve) already. Forgot to mention: car is a double fuel (petrol + LPG, not friendly to exhaust valves). That's the reason. And previous owner didn't care (didn't bother to adjust valves) probably. Calculated shim sizes are not obtainable, but there are close ones. If you can, try to put a little "too small (too thin)" shim. It's better when clearance is just a bit bigger (valves will "seat" naturally making clearance smaller).
18. If you have stash of old valve shims, from older Fiat models, they're useless now. Back in the days, shims were thicker (let's say 3-5 mm range), now you need 2-3 mm range. Diameter is the same (31,00 mm).
19. There is a minimal shim thickness, you cannot adjust the valves forever. Shim must stick out of the tappet. If not, camshaft lobe will crash into tappet edge. Didn't measure (tappet shim seat depth), but in my case, values like "2,20 mm" are probably (99,9% sure) last adjustment (shim barely protrudes). Next time it's a valve job...
Guide ends here, next page and points are informational only ("conversation piece")...not so "DIY".
After adjustment car started with no problems, engine runs just fine, no error codes.
Thanks stefanos 4gr thanked for this post
Likes SRafferty, stefanos 4gr liked this post
Contents
<< <    Next Page: Extra info. Not so DIY anymore. (Page 1 of 2)    >  >>
Old 19-08-2018   #1
Vatican City
Smile Re: Valve clearance check and adjustment [1,4 8V]
Update.
New "rocker cover" gasket arrived. As mentioned earlier, make sure you order complete set (cover gasket + 4 small round ones). New gasket needs some help, put dab/drop of RTV silicone into 4 "corners" (where gasket "arcs" begin/end), that's official Fiat recommendation.
"Alignment" pin is not so aligning. There's too much "play". Classic "brain fart" by Fiat designers.
So, cover is "floating" all over the place (animated GIF).
But, don't worry. Somehow, cover will "seat" roughly in the same spot as with old gasket (I've measured, there was about 0,1-0,2 mm difference, comparing to numbers taken before adjustment job).
Engine started fine, and I didn't noticed any difference in performance.
After adjustment (and before cover gasket replacement) I've run procedures like resetting parameters and phonic wheel learning (or whatever it's called), and there was no change whatsoever.
So, special tool for cover installation is probably (99% sure) straight "bluff" ("wind-up").
Small note: if you adjust the valves "little too loose (bigger gap)", engine may be "little" bit noisier. So, clearance should be spot-on, regardless of "tolerance".
Likes stefanos 4gr liked this post
Last edited by GrandePunto PL; 19-08-2018 at 15:14. Reason: Clearance must be precise (forget tolerance).
GrandePunto PL is offline Reply With Quote Quote
Old 15-09-2018   #2
Vatican City
Post Re: Valve clearance check and adjustment [1,4 8V]
One more thing. If you buy 3 decimal places shims, there are different "styles".
They give away size (thickness), that's no-brainer.
Or confusing two similar numbers...
Set of such shims. Some weirdo "egg-head" designed those markings.
Top/upper digits are part number. Bottom is the size.
Examples of original packages.
If you want to judge condition of used shims, here is an example. Top 3 ones are in better shape, bottom not so much (to be replaced).
Serious pitting going on. Soon it will escalate into cracking, chipping.
Scoring, scratching, scuffing. Sign of, among others, contaminated oil.
That's all, for now...
Likes stevo123, stefanos 4gr liked this post
Old 20-04-2019   #3
Where can i buy the shims of this size?
anku is offline Reply With Quote Quote
Old 21-04-2019   #4
Vatican City
Exclamation Re: Valve clearance check and adjustment [1,4 8V]
If you can't find suitable ones on eBay (search internationally, not UK-only) or other on-line automotive shops, try local engine repair shops (some will sell parts) or local official/authorized Fiat dealer/service (some of them should have in-house shops and sell original spare parts - but I'm not from UK, so I don't really know what's going on there, if it's normal practice by dealers/service centers to sell so specialized parts to individual customers).
Last edited by GrandePunto PL; 21-04-2019 at 21:25. Reason: Try the engine shops and Fiat service. Or search abroad.
Old 18-08-2019   #5
Vatican City
Wink Re: Valve clearance check and adjustment [1,4 8V]
Update 2019.
Another check and adjustment after only 17000 km (because LPG fuel - it wears valves fast).
In theory, most values were in the tolerance, but I had suitable shims to tweak em.
Now engine runs a bit smoother.
If you ever rip-off the oil gallery seal (attached to the cover gasket), you can't leave it just like that. It will leak eventually and spoil the VVT operation and camshaft lubrication.
Quick fix is a thin strip(e) of the steel sheet, about 0,05 mm (so it can be cut with regular paper scissors). Length to do full circle, and cannot stick out of the groove. Works great.
Last edited by GrandePunto PL; 18-08-2019 at 18:00. Reason: Everybody. Check your valves regularly.
Old 4 Weeks Ago   #6
Vatican City
Adjustment 2021.
The LPG fuel keeps eating the exhaust valves and seats (current "mileage" 151000 km).
There will be a full valve job soon (in 2-3 years or 200000 km max. I guess), engine head repair. Because you cannot put thinner and thinner shims forever, there is a lower limit (1,80 mm).
To really see what's going on, do yourself the graph/plot like that. Shims size versus time. Wear is speeding up (3 out of 4 exhaust valve shims are getting smaller/thinner faster and faster with time), graph is steeper each year.
Also valve clearance, before and right after adjustment tells a lot. Exhaust valve number one is misbehaving the most, valve "lash" always wants to go down consistently.
Example of shims manufacturer. Range 1,80-3,30 mm. There are FIAT part numbers...
...But watch out. Each part number covers a small range of shims ("tappet plates") sizes (and those ranges are overlapping). So "part number" alone is not enough to order correct size. Available "plates" are from 1,825 to 3,330 mm. In practice shims under 2,00 and above 3,00 mm are rather rare in Grande as far as I know.
Shims have some tolerance, so can be off a bit (despite having 3 decimal places in nominal size, they are not that precise). Example: 4 shims "2,100" mm and real sizes. So it doesn't make sense to measure them to the 3rd decimal place with fancy equipment (2 is enough, like digital caliper gives you).
Last edited by GrandePunto PL; 4 Weeks Ago at 00:22. Reason: ...Do NOT neglect the 8V engines maintenance!
Comment
Search this Guide:
Valve clearance stirling Tech Talk 19 14-08-2013 00:34
(G) valve clearance pondy Punto (Mk2/2b) 9 08-07-2008 18:03
(G) Is valve clearance check necessary when replacing HG? jdf Punto (Mk2/2b) 4 28-03-2007 21:30
(T) Valve clearance check Scaniaman Tipo (Classic) 5 27-03-2006 13:47
