H hcloseuk New member Joined Oct 6, 2009 Messages 47 Points 28 Jan 24, 2022 #1 2015 1.3d Hi I'm having an issue with glow plugs not working on my van checked each one individually for power supply and found that 2 are not getting power is this a fault with the relay any help would be very much appreciated
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 36,798 Points 8,378 Location Near the M4 Feb 12, 2022 #2 Hi Did you figure this out?
OP OP H hcloseuk New member Joined Oct 6, 2009 Messages 47 Points 28 Feb 12, 2022 #3 Yes thanks turned out relay problem but changed glow plugs also
D daveaclayton Member Joined Sep 20, 2012 Messages 20 Points 54 Location Hemel Hempstead - UK Feb 19, 2022 #4 For those that may still have the issue. You can get a cheap 2nd hand relay on ebay - loads of cars use the same bosch part - 55203394 or 0281003043might be worth a try, before going for the glo-plugs...?
Jack2207 New member Joined Oct 14, 2022 Messages 9 Points 2 Location Nottingham Oct 14, 2022 #5 hcloseuk said: Yes thanks turned out relay problem but changed glow plugs also Click to expand... how did you find out it was the relay
