Hi, Does the -13 suffix on the code point to something more specific?Ok Thanks Anthony, I think it coming to that, as the relay checks out ok on the bench.
Hi, 12v as far as I can tell, 12v on pin 30 relay from f02, harness colours from relay same as plug on the engine where it splits into 2 pairs to the glow plugs.Hi
Your current test approach sounds a good one. From memory, each plug draws something like 15 amps when cold which drops down to 10 Amps once it heats up after 5 or 10 seconds. They are nominally rated at 11 volts, but a battery not being charged won't be far different once you allow for a bit of drop in the wiring.
I am assuming here that the plugs haven't been updated by Fiat over the years to a type that needs a lower voltage via some sort of controller.
Hi, I agree, That the plug is short circuit, I've left F02 out for the moment. The error code P0683-13 Preheating control unit (feedback) Open circuit.Hi
That's pretty conclusive. I had one plug fail short circuit on my 2008 X250 Ducato about 4 years ago. I used a workaround, which involved wiring a 1 Ohm metalclad power resistor (on a heatsink) in place of the faulty plug so that the Relay over current trip doesn't happen and the current self-test "sees" the right current and therefore passes. I never use the vehicle in weather cold enough to need all 4 plugs, and it seems to start just fine with only 3.
The alternative, given the age of the vehicle, would have almost certainly been specialist extraction of the seized plug and a £££ bill with very little benefit to me.
You may find that your plug can be extracted without issue, given that the vehicle is fairly new.
I made some progress in the meantime. The voltage measured at the main hot wire at the relay input is showing around 11.9V while the battery voltage is around 12.3V and that was suspicions from the start. So, when I connect the plug directly to that wire, before relay, it stays completely cold and the measured current is zero. When I connect plug directly to the fuse in the fusebox it gets hot and current starts from 18A when cold and drops to around 10A when hot. Cince the Giulia's plugs nominal voltage is 7V for this experiment I used glow plug from another car which is 11V. The fuse is ok and now I suspect that the problem is either in the wire itself or maybe at connection terminals. To check that I need to access the fusebox from behind and that requires some work, but unfortunately the weather is now cold and I don't have a garage so I need to wait.0.2ohm is quite low and I suspect the relay is shutting off the power because it sees it as a short. did the error P0683 got solved by replacing the relay?
Hi Anthony,Hi Pedja
If the Glow Plugs in your 2.2 Alfa are 7 Volt nominal types, they will actually be driven with PULSED battery voltage (11 to 13 Volts). The voltage (and current) go on and off rapidly (32 Hz typical), with this switching performed by a Mosfet switch in the glow plug controller. With a resistance of about 0.4 ohms, during the pulse the current will be about 30 amps and the power will be 360 Watts. With a typical duty cycle of 50% on and 50% off, the AVERAGE power is controlled to about 180 Watts, but this can be altered by the ECU to suit the engines requirements. The RMS (root mean square) voltage to the glow plugs will be about 7 volts, but you may need a specialist meter to read this accurately.
As with all glow plug systems, the total current drain for four plugs is very high, so the main feed to the glow plug controller must have good electrical connections all the way through. I think you are right to be looking in this area, examine every joint and contact.
