How about a context sensitive glossary, which underlines words (like arb, and carb, etc...) with some help text like a description or the unabbreviated meaning (so for arb - Anti Roll Bar - Suspention Component) when you hover your mouse over it.
ben said:Updated CAM but BOB isn't in Wiki....
I think PSI might be good too?
While I think about it, perhaps that's another suggestion worth making to the writer of the mod -- to have a system whereby each word can be put in and flagged as being case sensitive or not.... so that things which are really obvious "real" words like map or pass can be set as case sensitive....?ben said:The easy answer is no, basically, in your example above, you typed ecu in llower caseso i would to put in all possible cases to make it work...
Fiat, fiat, FIAT, etc etc....
