lycopersicum
Hello everyone,
I bought a 2013 Ducato (2.3L 130 hp, 150,000 km) three weeks ago and quickly ran into engine trouble.
First drive: 500 km (highways), a "check glowplugs" warning came on but otherwise it ran perfectly fine.
Took it to the garage to get that fixed, it was a disconnected cable on one of the plugs.
Second drive: 500 km (highways), worked fine for 2 hours and then the cruise control started disconnecting randomly every hour or so. Later the check engine light came on while downshifting at a toll booth.
The next day I drove it to a garage. The check engine light was off when I arrived; they couldn't find anything wrong aside from noise that suggested a worn clutch fork or thrust plate (slight clanging noise in neutral that goes away when depressing the clutch pedal fully).
Third drive: 500 km (highways). Again it worked fine for 2 hours, then the glitches started again. This time I didn't use the cruise control; with each glitch the engine RPM would abruptly dip with a jolt and come back up to speed after half a second. This happened twice and then the check engine light came on exactly the same way, while downshifting at a toll booth.
The next day I drove it to a FIAT garage. Again the check engine light was off when I arrived. They found a bunch of warnings, cleared them, saw that the oil level was too high (maybe 1-2 cm above max) but told me that didn't need fixing. They took it on a test ride, said it ran fine and thought it was dirty fuel. They told me to just reset the car if the check engine light came back on.
Fourth drive: 500 km (highways). Same pattern: it worked fine for 2 hours, then the glitches started again. Later the engine light came on while accelerating together with a big puff of white exhaust smoke that lasted maybe 5 seconds. From then on it was in limp mode and couldn't get out of it by resetting the car. I left the highway and while reversing to park the engine stalled with a warning about oil pressure. So I got it towed to a garage and I'm hoping they find something this time, but they're too busy to look at it at the moment.
I'm a little worried that I bought a problem car. What do you think of all this?
There was no other warning light and the temperature gauge was exactly mid-range whenever I looked (which I'm now thinking is a little suspicious).
