Technical  Gear selection problems
If it happens intermittently check your clutch slave cylinder. They are known to fail. Difficult or slow gear selection (no crunching though) which is ok a few minutes later is a symptom. If you continue to change gear when this happens you will wear out your clutch. My multi was especially prone to this after a thrashing when I guess the slave cylinder got too hot.
