General  Gear Leaver
General  Gear Leaver
decourcey
Hi my husband has just bought a Fiat Multipla 1.9 diesel X reg.only problem gear leaver seems to be very tight. its not smooth in any way you sort of have to push it with some strength into gear,does any know how to solve this problem.
OK, try lubricating everything, this means clutch actuating arm, external gear change mechanism, etc. This is located on top of the gearbox and the battery and/or airbox need removing to access this.
Is it the same in all gears or is it more pronounced in 1/3 or 2/4.
You need to check the hydraulic clutch mechanism to make sure that clutch is not dragging and that the clutch isn't on the limits of wear.
Last, check the gear change cables and make sure they aren't compromised.
Also, some folk have had success in changing the gearbox oil, X reg is probably well overdue.
