Hi!
I have a 2003 1242ccm petrol 44kW.
Today while driving the rpm suddenly fell back from 2300rpm to 1800rpm after this was nothing wrong with it. When I stopped for the second time the engine cut off. I tried to restart it but the gauges went crazy. The speedometer rised up to 20km/h, the enigine’s temperature indicator went up and down, and itt took very long for the lights to siwtch off. The car is cranking by the way. The key icon randomly keeps switching on and off with each ignition. I tried two different keys. When it started after many tries the engine went off while driving around 40km/h. After I started it again it had the same symptoms. I pulled up on the side of the road, it shutted down on idle. The fault code from the ECU is U1600 and U1601.
The car did this several days before expect the rpm issue. Back then I soldered the end of the cable which is go from the battery to the engine fuse box. (The other cables are soldered too expect this one, that's why I did it.) The problem went away, but today this happend.
Does anyone have any idea?
Thank you!
Thank you!
