General  Fumes in cabin
Carton
Birmingham
Morning,
54plate panda petrol
Car was running fine but time for MOT and service.
So booked it in and had usual done.
When I picked it up there was a strange noise when driving.
Sounded like a slight exhaust leak
Took it back mechanic said there was a slight nick ( done by them) in the breather hose.
He said he had shortened it to remove nick as pipe was long enough and was now sorted.
Noise gone but now getting smell of fumes through air vents particularly when idling .
Is this related or separate?
I looked at breather pipe. Seems ok
No exhaust leaks
Gasket from air filter body onto throttle valve seems a bit loose but not excessive.
Any ideas please??
Year
2004
Mileage
21000
More often than not it the breather pipe
But there loads of other cause like oil dripping on the exhaust
Are you sure both the little and big breather hoses are solid,.it not unusual for ther to be a.split in the larger one at the.bend
I was thinking my best move was to replace the breather hose.
Sounds like a good idea
My breather hose split recently
Took it off to try and get a replacement
Didn't notice anything with ventilation fan off
As soon as I switched the blower on we were hit with oily fumes
So I've glued the hose back together and stuck it back on until replacement arrives
Edit: wait 21k miles?! What the
