Technical  Fuel overfilling?
lowaaa
Noticed this a few times, however I thought I didn't put the nozzle in properly.
I put the nozzle in and start filling up my car and notice that the nozzle keeps clicking to prevent me from filling up anymore. I assume somethings blocking it and causing the fuel to go back because it's stuck.
Whenever I ignore the click of the nozzle and keep filling, I see that the fuel ends up building up and at that point starts leaking out. Once I stop I do see the fuel swirling down at a rather slow rate.
Anyone got any ideas on what this might be? What's the fix like as well? Is it going to be a pain..?
Thanks.
It is a known problem on a Punto.
Have you tried twisting the handle towards the front of the car so it pushes hard against the flap and then the handle begins to point upwards slightly?
I got a low mileage fuel pipe and cap to see if it makes a difference and at the moment the problem is a as bad as ever!
Some pumps are worse than others.
I will try that, thank you.
