Technical  Fuel injector removal problem
Jaakko
Vantaa
I have a 2022 ducato engine multijet 2.2D 16V 118Kw in my Adria camper. It is currently undergoing an engine rebuild. But now I have a problem getting the fuel injectors removed. They are REALLY tight! I mean really really tight!!! There seems to be some kind of design flaw in these new engines. Does anyone have any experience removing injectors on these newer engines? How do I get the injectors off? Does Fiat have a special tool for this?
Model
2022
Mileage
55800
Many more modern diesels have this problem, some were due to rain/water running into the engine compartment rusting them in to place , but often it is the combustion leaking past the injector seals in the cylinder head allowing a build up of carbon around the injectors.
I have used a slide hammer tool with the correct adapters to screw onto the tops of the injectors and eventually got them out, although not on your model.
There are expensive hydraulic tools available and even companies that specialise in that job who can come to your site in some areas.
I am not sure about a specific Fiat tool, however am I right in thinking your engine is the one used in Fords? In which case that may be an area to explore.
i Have used various penetrating oils and even a commercial steam cleaner to "melt" away some of the carbon, but in the end I got a cheap slide hammer tool with the correct adapters for make of injectors, from eBay and it has worked on several vehicles, so something like that may be worth looking into.
However a word of caution, the first one I did disturbed a tiny ceramic ball valve in the top of an injector resulting in me buying an exchange injector. Since then I learned more and that type of injector I was able to rebuild although too old to even see inside them properly these days, also later piezo type injectors are highly specialised so best left alone.;)
So I'm not doing the repair myself, but the car is at a repair shop. Apparently they have a pretty strong hydraulic tool there, but the injectors just won't come out. Does anyone have any new ideas?
That is the sort of heavy duty hydraulic tool I saw as the last resort.:(:(:(
Some of those type include a vibratory/impact addition as well which may help, plus hot and cold treatment and anything that will break down the carbon and corrosion that is holding them in.
For something only three years old I am surprised.
Engine rebuild - looks like the engine is still in vehicle?
Why does it need engine rebuild?
Looks like cylinder head will have to be removed and injectors drilled out or get a reconditioned head.
Most definitely - I have used heat and freezing to good effect on severely frozen studs.
Quick cooling of frozen, seized items after heating can often be effective due to the physical shock upon a reduction of size from application of plumbers freeze spray.
It would be hoped that the workshop already employ such techniques along with the hydraulic puller.
