Hi there. In trying to code new injectors on my Ducato 2.3 120cv from 2007, I'm using MES and ELM 327 adapter, I have removed the famous resistor, I'm able to connect to the ECU and read the older injector codes but when I try to program new values It always said adaptator not allows that function. Not sure if I need yellow cable to do that. I have doubts also with the cilinders numbering, I'm assuming that the first one is the one located next to the timing belt.
Thanks in advance
Thanks in advance
