Front wiper keeps blowing fuse
A
Anonymous
Hi all
my front wiper kept blowing a fuse, i know its the front one because i have removed the rear one.
The wiper will get to the top of the screen and then just stop and blow the fuse. I stuck a bit of tin-foil inside a fuse to stop it blowing but that went on fire last night, thank god i cought it in time, so now i really need to fix this as i have no wipers and if it rains im ****ed!
what do we think? faulty motor?
cheers guys
P.-
i would wire the motor direct to a battery and measure the current it's pulling. that should give you an indication of whether it's the motor/linkage or wiring.
Wipe blow a fuse
Ive had the same trouble and I drive a Fiat Bravo 1.4 12V 1996! I've changed once a 20 fuse then it blew and i put a 30 fuse. Now it is working...so far! ;)
cheers
Matteo
Re: Wipe blow a fuse
changed to a 30a fuse.. doing the job for now BUT!!!
My wiper is parking in top of the screen, the exact opposide of where it should be!! is the relay fried?
its a fire risk to replace fuses with an higher rated one.
a new wiper motor is far cheaper than another car.... :(
Craig, its called natural selection. :)
If the wipers are stopping and blowing fuses it means the linkage and/or motor are sticking. Get a haynes manual, take them apart, see whats worn, replace and regrease.
Wiper motors should not draw 30A, you will damage the motor, the wiring, the switch...
yeah it must have been a massive draw to make the fire...
anyways, will take apart the linkage ect.. will spray grease do the job?
God no! Proper gloopy grease. Spray grease dries in days and stops working.
753
Dark Lurker
J
3
786
Dark Lurker
2
751
Sabre 23
S
