Technical  front wiper blade
bevt666
Hi i am new to all this. The other morning i came out to find my windscreen frozen.I applied de-icer to the screen then jumped into the car to turn on the wipers to clear the windscreen,the wiper moved about an inch then stopped dead. I have checked the fuse which is fine,I can also here the motor but have no movement on my front wipers at all any ideas?
Hi, :)
normally there is a linkage on a ball-joint which CAN wear and pop-off
the wiper motor isn't the easiest to access. my suggestion would be;
with power OFF, lift up BOTH wiper arms so the "stand to attention"
then see if either will move in their natural arc..
if 1 does , but not the other it's a linkage popped off:eek:
FYI = https://www.fiatforum.com/punto-mk2-2b-guides/303128-cheap-fix-wiper-failure.html
let us know what you find, ;)
Charlie - Oxford
I have the exact same problem, happening in the exact same situation on Friday morning. Did you manage to fix it, and if so, how?
