![]() | #1 | ||
Posts: 4 Thanks: 0 Trader Rating: 0 ![]() | wiper motor and linkage Hi Apologies if this is covered elsewhere but I couldn't find anything when using the search option. The front wipers on our 59 Grande Punto are not working and we've been advised by 2 separate garages that we need a new motor and linkage. We received a couple of quotes of between £200 and £250, but then another who will fit it for around £50 if we have the part. I've ordered the part for £90 but I was wondering whether I could have a go at fitting it myself. Can anyone point me in the direction of some step by step instructions or offer any advice? Many thanks
![]() | #2 |
![]() | Re: wiper motor and linkage shouldn't be too hard biggest issue will be to remove the wipers from the spindle.... https://www.fiatforum.com/grande-pun...placement.html top few pics show the parts to remove to get the plastic trim off use great care not to apply any pressure to the plastic trim i did and cracked my windscreen (insert relevant string of expletives here).. then at a guess its remove the electrical multiplug then the bolts holding it and a straight swap.... whilst your in there clean the scuttle out no doubt it will be full of muck and check the 2 rubber drains are clean and clear of debris |
![]() | #3 |
Posts: 3,291 Thanks: 148 Trader Rating: 0 ![]() | Re: wiper motor and linkage I am doing this job myself today I got motor and linkage fot 30.00 from a scrapyard. I will let you know how I get on.
__________________ ![]() “Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Instagram: 1985SJB |
![]() | #4 | ||
Posts: 4 Thanks: 0 Trader Rating: 0 ![]() | Re: wiper motor and linkage Thanks to both of you for your help. SJB1985, would be good to hear how you get on
![]() | #5 |
Posts: 3,291 Thanks: 148 Trader Rating: 0 ![]() | Re: wiper motor and linkage So I removed the windscreen wipers and removed the scuttle panel and to be honest it was pretty straight forward from there. Remove one whole wiper moter and linkage and replace it with another in reverse. I am sorry I didnt take note to make a gude but this is not a hard job at all. in fact, removing the heater blower and replacing the pollen filter is harder. Regards Stephen
![]() | #6 | ||
Posts: 4 Thanks: 0 Trader Rating: 0 ![]() | Re: wiper motor and linkage Excellent. Hopefully I'll be able to get this done then ![]()
![]() | #7 | ||
Posts: 4 Thanks: 0 Trader Rating: 0 ![]() | Re: wiper motor and linkage All done. Only problem was numb fingers. Not the best idea to do this sort of thing in the snow, having to wipe ice away from every surface.
![]() | keveen | Punto (Mk2/2b) | 5 | 29-08-2011 13:30 |
![]() | maca123 | Cinquecento / Seicento | 6 | 08-02-2009 22:02 |
![]() | circolo | Bravo / Brava | 2 | 15-08-2007 13:16 |
![]() | 01punto_funkybro | Punto (Mk2/2b) | 0 | 25-01-2007 15:58 |
![]() | thefishdude | Punto (Mk2/2b) | 5 | 05-12-2005 18:21 |
