- Joined
- Sep 14, 2009
- Messages
- 20,105
- Points
- 4,011
Ive had a noisy bearing probably the left but cannot be sure. I had replaced that one last year so could it have failed already? Anyhow I'm sick of the noise so bought a pair of SKF from S4P. I don't have a hydraulic press so got one of these kits.
https://www.ebay.co.uk/itm/23Pc-Fro...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
It's Chinese of course which wrankles, but the "professional" brands are silly money and most likely made in China so I sucked it up and bought one.
The quality is frankly amazing and it works well. There is no way anyone could make it for £35.
Expecting to extract a wheel bearing on the car is pushing your luck. Though perhaps worth a try. I does extract outwards. However mine were off the car as I'm doing the gearbox oil seals and a drive shaft.
One bearing was solid tight. It had to be hauled up tight then thumped on end with two lump hammers (one each side) and tightened again until the bearing started to move. Even then it was extremely hard work. I had two 600mm breaker bars on the job. The hubs were off the car.
My adapted ball joint separator was perfect for knocking the wheel drive flange out of the bearing.
Both drive flanges came out with a bearing inner ring. However, there is no chamfer to get a wedge between bearing and flange. I cut a slot (at an angle) into the bearing race with the angle grinder slitting disc. It goes through hard steel like butter so take care not to cut into the flange. Once it's slotted a hard clout with a cold chisel will crack the bearing ring.
The press kit pushes the flange into the new wheel bearing.
