Styling  Footwell Neons
Kinross
I'm probs not going to get them but I'm just curious as to how you would wire these up
One of the stupid people i know has just got one of those plug and play ones from the cig lighter but now he cant use the cig lighter for sat navs charging ipods or even lighting fags!
Can you just splice into the two wires at the back of the cig lighter? If so how many neons could you run in this way and could you still use the cig lighter for things like sat navs and charging ipods etc?
Fank yhoo1
Yes and yes. I don't know how many you could safely run from it but if you planned on wiring in loads you'd be better putting them all on 1 system straight from the battery with a switch on the circuit inside the car.
Just ask Brin, his car is like blackpool illuminations
I currently have 12" Cold Cathode Lights in mine
Same sort you have in a PC
I'd actually wired mine off the cigarette lighters Light (2 prongs)
Work perfectly fine till you kick a tube :( (n)
I'd look at putting those SMD Light Strips or an LED Strip in
They can mould to a better shape - less sticking out - and will take a knock or too
I've not fused it - as it draws very little, just have an inline switch
Ziggy
