Hi all I have a gp 1.4 active sport 06 my starter motor is sometimes not working just get screeching noise is the flyweel dual mass and is the starter likely to have caused damage thanks all
Jonny I wouldn't have thought the 14. 16V wouldnt use a dual mass flywheel, it doesn't have enough torque to warrant it. Normally that's reserved for Diesels or larger capacity engines. With that said, do check with a dealer by asking them to quote for a flywheel for your car, then ask them to confirm if dual or single Don't go buying it of course, just use them to get the info you need.
From what you describe it does sound like a sticky starter. I would take the car to a local mechanic, any old spanner monkey should be able to manage fault finding and changing a starter. Its even doable at home
