Technical Fiat stilo blue 1.4 cold starting issue
ObScEANe
Hi all,
I have a fiat stilo blue 1.4 6 speed.
When starting the car when cold (first thing in the morning for example) it struggles to start, engine pitch is very low then it kicks on after a couple of seconds as you would expect normally.
Checked battery and even left on charge overnight a few times. Swapped all 4 coils. No change.
Car starts fine when warm or previously been started recently. Any ideas?
Have only done 58000 miles, had belt changed and serviced regularly.
Obs
dtimmins1985
Established member
West Yorkshire
Hi all,
Obs
Could be a few things really:
faulty battery - not holding charge properly
faulty alternator - not charging battery properly
starter motor could be on its way out
finally - cam sensor... - when these go, the car will only start when warm or has to be bump started when cold.
br,
Dan.
