Fiat seicento sporting
adam spurr
Hi all I just bin driven home from work went to put my car back into first at a set of light all I heard was a knock and my cluch pedal is just on the floor and will not mover car is a s reg seicento sporting anyone no what could be the problem thanks
something has snapped, most likely clutch cable or plastic quadrant. Normally a sign that the clutch itself (well, the release bearing) is on the way out and it's putting too much stress through components.Not always though, but that's usually the way of it.
Other possible parts that could have gone are the linkage bar or the pedal linkage, but these are pretty rare in comparison.
First thing's first, have a look at the cable and see if it's intact (pulling the cable with a pair of pliers ought to do it), second thing second, lift the clutch pedal by hand and feel the linkage attatched to it, then have a look at the gold bar that runs across from what that connects to and wiggle that, if that's not flapping about wildly then it's the quadrant, which is located in the passenger footwell behind the carpet, it connects the clutch cable to the linkage bar and is plastic. But as said the only real reason for these to go is a heavy clutch, which means new clutch time.
Thank I will take a look today the clutch didn't seem heavy at all it seem to be operateing fine before the problem come a cross
