Because they're fashionable. The 500 sells (and has strong residuals) because of its looks and kerb appeal, not because of its quality, maintainability or cost of ownership.Why are these cars so popular, expensive to buy and expensive to keep on the road.
The common wearing parts are cheap enough (though the dealer only items are a different story). What kills it for most folks are the labour costs (us DIY types are only a small percentage of 500 owners).I've found most are relatively cheap
My 169 is still running on all its original suspension after 12yrs/105k and has just passed an MOT, though one of the droplinks will need replacing soon. It's easily the 100k+ car with the fewest replaced components I've ever owned. By comparison, my 500 has been the least reliable and most problematic new car I've had.My 169 panda had 'geometry issues' around 7 years old.
As long as the offset it right, what do you think that stresses?sticking wide alloys on a chassis built for a shopping car running on 155/13's was always going to stress things..
That's why is so odd, you'd think they'd be the same car underneath, and I heard good things about panda, and asumed the 500 was the same car different bodyshell.Panda; easier to maintain and with fewer inherent weaknesses.
There's several factors working against the larger wheels. For a start, they're heavier, so there's that much more unsprung mass pounding all the joints in the suspension. And it's not just the mass; the rolling inertia will be considerably greater, so the gyroscopic effect is putting extra stress on all the steering parts every time you corner. Plus, even slightly uneven tyre wear will soon put the wheels out of dynamic balance, and that effect is greater with wider tyres.As long as the offset it right, what do you think that stresses?
And basically it is; but the little differences all seem to work against it. Things like broken hatch wiring, door handles which come off in your hand, door mirrors which break off if folded regularly - all these are practically unheard of on the Panda 169. Things on the Panda which are easy to change need more dismantling on the 500; for example, the bumper has to come off to remove the wishbones. And once you go higher spec, the climate control has a nasty fault which requires most of the interior forward of the driver's seat to come out (admittedly this fault exists on Pandas with climate, but there are far fewer Pandas so equipped). The 500 seems to run into far more electrical issues than the Panda, particularly the speedo and MFD, which regularly give problems - this is unheard of on the 169. Lighting problems are more commonly reported also.That's why is so odd, you'd think they'd be the same car underneath, and I heard good things about panda, and asumed the 500 was the same car different bodyshell.
I'm not sure I agree with all that, the pounding should be in the direction of the shock and spring, they are designed for that, the other joints, like wishbones should only have lateral forces, and it;s the wheel pulling the car, and unless the skinny small tyres are slipping,then they'll have the same force on them of pulling the car along.There's several factors working against the larger wheels. For a start, they're heavier, so there's that much more unsprung mass pounding all the joints in the suspension. And it's not just the mass; the rolling inertia will be considerably greater, so the gyroscopic effect is putting extra stress on all the steering parts every time you corner. Plus, even slightly uneven tyre wear will soon put the wheels out of dynamic balance, and that effect is greater with wider tyres.
Well, ours was just under 5 years, and 30k miles when bought, so I was expecting 5 years or 50k miles before needing anything other than usua; car stuff. I've owned a lot of old cars, and the 500 is by far worse than most of them.Let's remember we're talking about cars that are 2007+ like over 10 years old now.
I am sure these bushes could be obtained from a specialist supplier. My 2014 Panda at 37,000 miles have just started clonking so maybe Ill find out. If I find bushes I shall buy half a dozen sets and put the extras up at cost on here. Renaul are another similar cost band make and I have had dampers last 100,000 miles on them and still found to be perfectly serviceable on replacement. The quality is however well above the integrity and honesty of Fiat!MOT fail, rubber mounts have perished on the shock absorbers. 40k miles seems "shock"ingly bad for a modern car.
However your car had done only 6000 miles a year, which means mostly city driving. City driving is double or even triple (or more) the wear on the components than driving longer distances. Old granny driver could probably make it last forever though. So triple the mileage and see that probably a car equivalent of 90k miles of wear with same repairs wouldn't be so bad after all. Cars don't last forever, they age even when they're not driven that much. Soon you're going to have to replace the clutch too.Well, ours was just under 5 years, and 30k miles when bought, so I was expecting 5 years or 50k miles before needing anything other than usua; car stuff. I've owned a lot of old cars, and the 500 is by far worse than most of them.
Wear, yes, though your figures are somewhat exaggerated, I've had many older higher mile cars that didn't have these types of issuesHowever your car had done only 6000 miles a year, which means mostly city driving. City driving is double or even triple (or more) the wear on the components than driving longer distances.
I do like fixing cars, though we got this one because it was newer and lower mileage than the corsa c it replaced. At three times the age, and three times the miles, the corsa was less trouble to keep on the road, you dont mind changing parts when you think "that's lasted well"I don't like having to repair the car either. Lots of people have the mentality that Fiats don't need to be repaired and any repair is too much.
Maybe the "type" of driver Panda generally the silver hair brigade 500 often newly passed drivers and the type of driving-to the shops or bowling and back or round town off to friends work etc?Seeing as the Panda and 500 are very closely related and must use the same spec' (if not actually identical) parts... there seems to be a bit of an unfair "downer" on the 500. If the Panda is bullet-proof, then the 500 should be too.
The parts themselves don't know that they're fitted to a 500, and therefore "must" go wrong,... but I dunno how some cars wear stuff out in 2 years and others, like the Younger Mrs S's Rasputin, seem to go forever on the factory parts. Just new front wishbones and a clutch slave cylinder for the 2013 beast, in 67,000 miles and despite an interesting (previous owners) life.
What's making people break them?
Ralf S.
