Basically means car fuel mix is being controlled by the reading from the first lambda sensor.
It uses the reading to control the mix of air and fuel.
When you cold start it is in open loop as the lambda needs to be hot, engine up to temp etc.
So the engine is forced to be rich ie have more fuel than air, hense exhaust stinks and revs are higher at start. A bit like pulling the choke out on older cars on start up, when everything is up to temp you push choke back in.
When in closed loop the ecu alternates the mixture from rich to lean so the Cat converter can work on the different gas produced.
https://secure.lambdapower.co.uk/TechNotes/Tech-3.asp
So yep sounds like your thermostat is working it will be shut ( no flow of hot water in to radiator) until up to working temp then open to keep engine at working temp.
Also sounds like your going into closed loop if the revs drop below 1000 after a bit.
disconnecting battery will clear codes.
