fiat panda 2017 rear side door wont open from inside or out any help in opening the door please
Read the many ‘similar threads’ at the bottom of this page…fiat panda 2017 rear side door wont open from inside or out any help in opening the door please
I agree with you, the hard bit is doing it with no damage, any idiot can prise the door card off to access the mechanism.Most 'fixes'. Posted are with the door card off..
I suspect that's a lot harder with the door closed..
@g4jvf
Whats failed in yours?Hi Guys will a 2010 panda rear door locking mechanism fit a 2017 panda?
The door lock has failed and i can't get door open so need to break out old lock and open door then refit new lockWhats failed in yours?
EPER is the FIAT parts systemHi Guys will a 2010 panda rear door locking mechanism fit a 2017 panda?
There is no pulse from the central locking, yes had to take seat base out to get door card of, i can't seem to find anything to do with door locks on the EPER parts systemEPER is the FIAT parts system
Use the forums version to compare parts numbers
How did you go about removing the door card
Did the seat base need to come out?
From the various people's efforts, it may not be "broken", just needs coaxing back into operation
Does the Central Locking still "pulse the lock"?
Take a look here.... the locks are listed under 'display units and windows', which is I think a translation errorThere is no pulse from the central locking, yes had to take seat base out to get door card of, i can't seem to find anything to do with door locks on the EPER parts system
I've got this exact same problem on my 2017 Panda. No pulse can be heard on the drivers side rear door when I unlock (manual key central lock - opens and locks all doors with one key in either front door) , all the other doors unlock no problem.fiat panda 2017 rear side door wont open from inside or out any help in opening the door please
I've got this exact same problem. No pulse can be heard on the drivers side rear door when I unlock (manual key central lock - opens and locks all doors with one key in either front door) , all the other doors unlock no problem.
Booked my car in for service today and asked them to have a look. They're quoting me £1200 to "smash off" the old latch and it will have to be replaced with a new one! Surely there has to be a simpler (and cheaper!) solution?
Any advice or point me to other thread where this has been resolved?
I was recommended a small independent 'car repair shop' by one of the MOT garages I shopped around at. They took the inside door panel off (without needing to remove any seats) enabling them to get a tool into the lock mechanism (breaking it) and flick the latch to manually open the door. Then they could remove the broken lock mechanism and replace with the new one I purchased from this seller on Ebay.
