rustysplit
- Joined
- Mar 25, 2008
- Messages
- 9
- Points
- 5
I've been looking at my son's car prior to the MOT as it has had the engine light on for a few weeks. Error code using multiecuscan software is P0226 - Accelerator Pedal Potentiometer. Code can't be cleared.
I have checked the electrical plug on the accelerator pedal and that is firmly in place. Also tried disconnecting battery for 15 minutes which has been suggested elsewhere but no change.
I'm assuming the cause is the sensor on the accelerater pedal. Is there anything else I can try?
If it needs replacing, can I just get the sensor or is it the whole pedal with sensor?
Also, if the sensor/pedal is replaced is there any software or process needed to reset the sensor?
Thanks for any advice.
