Technical Fiat palio 1.2 MPI compression issue
Sherwin26g
South Africa
Hi guys please I need urgently advice, yesterday my palio 1.2 mpi 8 valve stalled upon checking I saw that the crank only was turning found that timing gear was worn down,today I put new timing gear car started hundreds drove it around the block it drove perfect,just tried to take it out the yard and it switched off engine has fast swing like there's no compression but the crank and cam are turning,what can be the issue near in mind it didn't heat up n it isn't backfiring n popping,pls help I'm so tired of this car now
