Technical  Fiat Fullback Electrical Fault!
tgfitz
Cardiff
Hi All,
Ive got a 2017 Fiat Fullback 52k miles. Having an intermittent electrical fault originally thought it was the key as the key symbol with an exclamation was appearing on the dash. However, after changing the battery multiple times there was no difference. I was then informed it could be an issue with the stop start button as almost every time i make a journey now the same symbol appears on the dash but the radio & heaters turn off and the stop start button flashes red. There is also a constant beeping (which is extremely annoying). There is no affect to the performance of the vehicle and on some occasions after 15/20 minutes everything will return to normal.
Does anyone have any idea what could be going on?
Many thanks
Hi All,
Many thanks
Hi, did you get on with this? I have the same issue, and the plug in at the garage says low voltage detected, even though the battery voltage is fine. Don’t know if it’s a coincidence but the Kenwood stereo has also packed up! Any feedback would be good, truck starts, runs and drives as normal otherwise. Thanks.
