Hello all! hoping somebody can help us.
We have a Fiat Ducato 2.3 from 2014 (pre-facelift X250), converted to a camper-van. We are in Italy (we have been stranded here because of the covid lockdowns and finally returning home) and two weeks ago after a cold start the engine would not rev up and vibrates strongly while idling, the engine stops after a few seconds and the engine management light comes on. The logged code is P0697, I could only find two other threads searching for the error code, neither posted the solution.
If I press the accelerator while switching the engine on, then works as long as I keep pressing the accelerator. Once the engine is warm it works, starts and idles fine without having to press the accelerator.
After a trip to the mechanic, they reset the ECU and it worked fine, until now when it happens every time I start. I have taken it to 5 other mechanics, but they find it hard to diagnose because it only happens when cold and can't do much apart from resetting the ECU.
I can't find exactly what sensors are related to this ECU (edc16c39) anywhere
So far I have tried to check the cables from the sensor to the ECU, but my multimeter leads don't fit in the ECU connector pins (we are traveling so we don't have many tools). Last year we had a similar symptoms when a broken EGR pipe caused the DPF to become clogged, so I tried changing the DPF differential pressure sensor without luck.
Does anybody know exactly what sensors are related to this error code?
Would really appreciate any kind of help diagnosing this.
