No its just bog standard.. re; your previous post i was thinking the same, im just about to go outside in a mo and clear the codes and then retest it tomorrow after ive been out in in.
Wanted to get to the bottom of the clicking noise today and seeing that im always on my own, i got a large brush to push the accelerator down with my head in the engine
Well it is the EGR valve that is clicking its nuts off when i accelerate. had a play with the pipes and had a look at the actuator. there is a suction on there. so ran it again and it was a pile of junk couldn't drive much.
So i took the EGR valve off and you could see the pin going up slowly when i plugged the pipe back on, When i unplugged the actuator it fell, and rose when i plugged it back in. Same happened when i unplugged the MAF sensor. so it seems to be working, just not when i want to drive anywhere..
Now people have said blank it off, but how do you get the top off, as last time the top broke off so i didnt have to do anything, or is the EGR faulty and just not working as it should..
You blank it off at the flange at the exhaust manifold. If you know that its closing and make sure its closed then you can just clamp off the vacuum pipe some people shove a ball bearing into the tube so it look like its not been tampered with.
