Hello,
Brand new forum member here in search of some help!
I currently own a Fiat Doblo 1.9 Multijet (2006, 120) which I bought from previous owner in May 2019. For the past 3 or so months, the car will on occasion judder and emit white smoke from the exhaust when I slow down or come to a complete stop, and will only stop doing this if I switch the engine off and back on. Someone on good old FB said it could be the DPF filter, so I recently took it in to the garage.
The garage said the car had come up with a coolant sensor error code (the car was saying the engine was -39c when it clearly wasn't). They also had a further deep look and said the car is in otherwise good nick mechanically. They went ahead and replaced all the glow plugs and coolant sensor, and changed oil filter.
Fast forward to 2 days after getting the car back, and it had randomly started to judder and emit white smoke from the exhaust again. I sent a message to the garage asking if it could be a problem with the DPF filter or possibly with the ECU. The garage messaged me back saying that my car doesn't have a DPF filter so can't be that, but could possibly be that an injector is stuck. They've asked me to bring the car back in so they can run diagnostics again to see if that reveals anything (they're doing this free of charge).
So, questions:
1. Is it right that the model car I have never had a DPF filter?
2. What could be causing the judder and white smoke? FYI I live in Guernsey (Channel Islands) and max speed limit is 35mph. Father in law said that it may be the car isn't able to burn the particles as you legally can't drive at a high enough speed. He said buying a diesel additive should help this as he had the same problem with a different diesel car.
Also, could anybody tell me what the correct size wheels and tyres are for my car model? The garage mentioned that whoever's had owned the car before me had put on the completely wrong size wheels and tyres on the car... So naturally I need to sort that out too.
Thanks in advance!
So, questions:
Thanks in advance!
