Howdy,
Currently I've got a cinquecento 1.1 fire with lpg installed - first gen mixer, basically a carburetor with a couple of adjustments.
After fighting with the car for a couple of months of not running at all, then not running properly, intermediate running and finally running as well as I could with gasoline and lpg, which involved replacing/cleaning anything related to the fuel system, the lpg evaporator, the works.
I'm now trying to get about the same power out of the lpg as a stock 1.1 running on petrol.
I've done the basic steps, like de-smoging (mainly to clean up the air flow into the throttle body), punto 75 throttle with 75 spacer and I've got a 75 cam that I can drop in.
However, while I'm in there, I'd like to explore the possibility of advancing the timing some, since lpg has a higher octane rating, and I use it about 99.9% of the time.
From what I've seen, most people drill out the timing gear on the cam to get a couple of degrees in petrol applications, however I'm a bit more inclined with advancing the whole gear by one tooth.
Would this be feasible, or am I missing something?
