Alfa33boxer81
Hi guys, as you already read on the title, I would like to have some little info about the possible physical possibility of mounting a old type mechanical distributor there where the ignition coils are mounted?
The question is not, on making it work and fire properly. The question is does it fit in the hole on the head and if there is already some gear shape/tabs on the camshaft's end to copy with the distributor and make it rotate??? I have heard that all engines until 2002 MPI/SPI have the geared camshaft to house the mechanical distributor, but I'm not sure. Some say it would be possible only on the SPI engine ect.
Can someone please confirm this for me... It means a lot to me as my old man mechanic wants to do some experiments on a Fiat Panda and upgrade it but in the old fashion way
Thank you very much in advance
Best, Elvis
Best, Elvis
